New sensor state class: total
Note: This post was edited 2021-10-21 to remove references to total accumulated increases and decreases which were removed and never included in the Home Assistant 2021.10 release.
A new state class, total has been added and the last_reset attribute has been added back to SensorEntity and is no longer deprecated. The driver for the change is to support cases where total_increasing, which was introduced in Home Assistant 2021.9, is too restrictive to cover all cases. Note that setting last_reset for sensors with state class measurement is still deprecated.
State classes
There are 3 defined state classes:
  • measurement, the state represents a measurement in present time, for example a temperature, electric power, etc. For supported sensors, statistics of min, max and average sensor readings are updated periodically.
  • total, the state represents a total amount that can both increase and decrease, e.g. a net energy meter. When supported, the accumulated growth or decline of the sensor's value since it was first added is updated periodically.
  • total_increasing, a monotonically increasing total, e.g. an amount of consumed gas, water or energy. When supported, the accumulated growth of the sensor's value since it was first added is updated periodically.
State class total
For sensors with state class total, the last_reset attribute can optionally be set to gain manual control of meter cycles. The sensor's state when it's first added to Home Assistant is used as an initial zero-point. When a last_reset changes, the zero-point will be set to 0. If last_reset is not set, the sensor's value when it was first added is used as the zero-point when calculating sum statistics.
Example of state class total without last_reset:
t state sum
2021-08-01T13:00:00 1000 0
2021-08-01T14:00:00 1010 10
2021-08-01T15:00:00 0 -1000
2021-08-01T16:00:00 5 -995
Example of state class total with last_reset:
t state last_reset sum
2021-08-01T13:00:00 1000 2021-08-01T13:00:00 0
2021-08-01T14:00:00 1010 2021-08-01T13:00:00 10
2021-08-01T15:00:00 1005 2021-08-01T13:00:00 5
2021-08-01T16:00:00 0 2021-09-01T16:00:00 5
2021-08-01T17:00:00 5 2021-09-01T16:00:00 10
Example of state class total where the there initial state at the beginning of the new meter cycle is not 0, but 0 is used as zero-point:
2021-08-01T16:00:00 5 2021-09-01T16:00:00 10
2021-08-01T17:00:00 10 2021-09-01T16:00:00 15
State class total_increasing
For sensors with state_class total_increasing, a decreasing value is interpreted as the start of a new meter cycle or the replacement of the meter. It is important that the integration ensures that the value cannot erroneously decrease in the case of calculating a value from a sensor with measurement noise present. This state class is useful for gas meters, electricity meters, water meters etc.
The sensor's state when it's first added to Home Assistant is used as an initial zero-point. When a new meter cycle is detected the zero-point will be set to 0. Please refer to the tables below for how this affects the statistics.
Example of state class total_increasing with a new meter cycle:
t state sum
2021-08-01T15:00:00 0 10
2021-08-01T16:00:00 5 15
Example of state class total_increasing where the there initial state at the beginning of the new meter cycle is not 0, but 0 is used as zero-point:
t state sum
2021-08-01T15:00:00 5 15
2021-08-01T16:00:00 10 20
