Deprecating all SUPPORT_* constants
As of Home Assistant Core 2022.5, all SUPPORT_* constants are deprecated, each entity platform is providing an EntityFeature enum to replace them.
This applies to, the following platforms:
  • Alarm Control Panel
    Deprecated supported feature constants:
    • SUPPORT_ALARM_ARM_AWAY
    • SUPPORT_ALARM_ARM_CUSTOM_BYPASS
    • SUPPORT_ALARM_ARM_HOME
    • SUPPORT_ALARM_ARM_NIGHT
    • SUPPORT_ALARM_ARM_VACATION
    • SUPPORT_ALARM_TRIGGER
    Use the new AlarmControlPanelEntityFeature enum instead.
  • Camera
    • SUPPORT_ON_OFF
    • SUPPORT_STREAM
    Use the new CameraEntityFeature enum instead.
  • Cover
    • SUPPORT_OPEN
    • SUPPORT_CLOSE
    • SUPPORT_SET_POSITION
    • SUPPORT_STOP
    • SUPPORT_OPEN_TILT
    • SUPPORT_CLOSE_TILT
    • SUPPORT_STOP_TILT
    • SUPPORT_SET_TILT_POSITION
    Use the new CoverEntityFeature enum instead.
  • Climate
    • SUPPORT_TARGET_TEMPERATURE
    • SUPPORT_TARGET_TEMPERATURE_RANGE
    • SUPPORT_TARGET_HUMIDITY
    • SUPPORT_FAN_MODE
    • SUPPORT_PRESET_MODE
    • SUPPORT_SWING_MODE
    • SUPPORT_AUX_HEAT
    Use the new ClimateEntityFeature enum instead.
  • Humidifier
    • SUPPORT_MODES
    Use the new HumidifierEntityFeature enum instead.
  • Fan
    • SUPPORT_SET_SPEED
    • SUPPORT_OSCILLATE
    • SUPPORT_DIRECTION
    Use the new FanEntityFeature enum instead.
  • Light
    • SUPPORT_EFFECT
    • SUPPORT_FLASH
    • SUPPORT_TRANSITION
    Use the new LightEntityFeature enum instead.
    Note that the following light constants were already deprecated, thus LightEntityFeature does not provide a replacement for those.
    • SUPPORT_BRIGHTNESS
    • SUPPORT_COLOR_TEMP
    • SUPPORT_COLOR
    • SUPPORT_WHITE_VALUE
    These cases should instead be migrated to the new color modes.
  • Lock
    • SUPPORT_OPEN
    Use the new LockEntityFeature enum instead.
  • Media Player
    • SUPPORT_PAUSE
    • SUPPORT_SEEK
    • SUPPORT_VOLUME_SET
    • SUPPORT_VOLUME_MUTE
    • SUPPORT_PREVIOUS_TRACK
    • SUPPORT_NEXT_TRACK
    • SUPPORT_TURN_ON
    • SUPPORT_TURN_OFF
    • SUPPORT_PLAY_MEDIA
    • SUPPORT_VOLUME_STEP
    • SUPPORT_SELECT_SOURCE
    • SUPPORT_STOP
    • SUPPORT_CLEAR_PLAYLIST
    • SUPPORT_PLAY
    • SUPPORT_SHUFFLE_SET
    • SUPPORT_SELECT_SOUND_MODE
    • SUPPORT_BROWSE_MEDIA
    • SUPPORT_REPEAT_SET
    • SUPPORT_GROUPING
    Use the new MediaPlayerEntityFeature enum instead.
  • Remote
    • SUPPORT_LEARN_COMMAND
    • SUPPORT_DELETE_COMMAND
    • SUPPORT_ACTIVITY
    Use the new RemoteEntityFeature enum instead.
  • Siren
    • SUPPORT_DURATION
    • SUPPORT_TONES
    • SUPPORT_TURN_OFF
    • SUPPORT_TURN_ON
    Use the new SirenEntityFeature enum instead.
  • Vacuum
    • SUPPORT_TURN_ON
    • SUPPORT_TURN_OFF
    • SUPPORT_PAUSE
    • SUPPORT_STOP
    • SUPPORT_RETURN_HOME
    • SUPPORT_FAN_SPEED
    • SUPPORT_BATTERY
    • SUPPORT_STATUS
    • SUPPORT_SEND_COMMAND
    • SUPPORT_LOCATE
    • SUPPORT_CLEAN_SPOT
    • SUPPORT_MAP
    • SUPPORT_STATE
    • SUPPORT_START
    Use the new VacuumEntityFeature enum instead.
  • Water Heater
    • SUPPORT_OPERATION_MODE
    • SUPPORT_AWAY_MODE
    Use the new WaterHeaterEntityFeature enum instead.
