Weather entity refactoring to support unit conversions
WeatherEntity now supports temperature unit conversion following a similar pattern as the unit conversion supported by NumberEntity and SensorEntity.
Precipitation, pressure, temperature, visibility and wind speed are automatically converted according to the unit system configured by the users. In addition, users can override units for specific weather entities.
To make this possible, custom component integrations should be updated to override properties native_precipitation_unit, native_pressure, native_pressure_unit, native_temperature, native_temperature_unit,native_visibility, native_visibility_unit, native_wind_speed and native_wind_speed_unit, instead of precipitation_unit, pressure, pressure_unit, temperature, temperature_unit,visibility, visibility_unit, wind_speed and wind_speed_unit.
The same renaming has been done for the corresponding _attr_* attributes as well as for members of the Forecast typed dict
In Home Assistant Core 2023.1, overriding precipitation_unit, pressure, pressure_unit, temperature, temperature_unit,visibility, visibility_unit, wind_speed, wind_speed_unit, setting _attr_precipitation_unit, _attr_pressure, _attr_pressure_unit, _attr_temperature, _attr_temperature_unit, _attr_visibility, _attr_visibility_unit, _attr_wind_speed, _attr_wind_speed_unit and setting precipitation, pressure, temperature, templow, wind_speed on instances of Forecast is no longer supported.
