Changes to long term statistics APIs
Some changes have been made to the long-term statistics-related APIs to reduce response size and database load.
The changes are implemented in this PR.
This affects authors of code calling the following WS APIs:
  • recorder/statistics_during_period
    • A new optional parameter types has been added, which allows providing a list of statistics characteristics to include in the response. Possible values are: "last_reset", "max", "mean", "min", "state", "sum"
    • Timestamps start, end and last_reset are now an integer number of ms since the UNIX epoch instead of ISO-formatted strings. The new format means the timestamps can be passed directly to js Date() constructor.
    • The statistic_id is no longer repeated for each list item in the returned map. This was not used because the return type is a map, keyed by statistic_id.
This affects authors of code calling the following Python APIs:
  • homeassistant.recorder.statistics.get_last_short_term_statistics
    • A new parameter types has been added, which allows providing a set of statistics characteristics to include in the response. Possible values are: "last_reset", "max", "mean", "min", "state", "sum"
    • Timestamps start, end and last_reset are now an datetime objects instead of ISO-formatted strings.
  • homeassistant.recorder.statistics.get_latest_short_term_statistics
  • homeassistant.recorder.statistics.statistics_during_period
