Entity state color changes
Frontend
From the Home Assistant Core 2022.12 release, we are using different colors per domain when an entity is active. These CSS variables are no longer used:
  • --paper-item-icon-active-color
  • --state-icon-active-color
This means that any theme that has previously overridden these CSS variables will use the built-in colors for active states. All theses new colors are available as CSS variables too.
Warning
As we only officially support the primary-color and accent-color properties for themes, some colors can be added or removed between releases.
More details about theme configuration can be found in the Home Assistant documentation.
