Translating the name and attributes of entities
It's now possible to translate the name of entities, and this is preferred over hard coding a name in natural language in the Python implementation. Also, entity components provide shared translations, for example, for binary sensor device classes, which should be used to avoid translating the same thing multiple times.
Also, the frontend now has full support for translated entity state attributes for both the names and their values.
Warning
Pointing to translations via the translation_key property is currently only supported for entities with a unique_id.
Additionally, translating entity names requires that the has_entity_name property is set to True.
Translating entity name
The following example strings.json is for a sensor entity with its translation_key property set to thermostat_mode:
JSON
  "entity": {
    "sensor": {
      "thermostat_mode": {
        "name": "Thermostat mode"
The following example strings.json is for a sensor entity with its translation_key property set to temperature_sensor where a shared translation provided by the sensor integration is used:
JSON
  "entity": {
    "sensor": {
      "temperature_sensor": {
        "name": "[%key:component::sensor::entity_component::temperature::name%]"
Translating entity attributes
The following example strings.json is for a demo domain climate entity with its translation_key property set to ubercool, which has custom fan_mode and swing_mode settings:
JSON
  "entity": {
    "climate": {
      "ubercool": {
        "state_attributes": {
          "fan_mode": {
            "state": {
              "auto_high": "Auto High",
              "auto_low": "Auto Low",
              "on_high": "On High",
              "on_low": "On Low"
          "swing_mode": {
            "state": {
              "1": "1",
              "2": "2",
              "3": "3",
              "auto": "Auto",
              "off": "Off"
For more details, see the entity name translation entity attribute translation and entity documentation.
