Updated to the Vacuum entity integration
The Vacuum entity has seen some recent changes:
  • The VacuumEntity base class was superseded by StateVacuumEntity by PR 15573 which was merged in August 2018, and has now been scheduled for removal in Home Assistant Core 2024.2.0. All core integrations are already updated, but custom component integration authors need to update their integrations. PR 95920 is a recent example of migrating from VacuumEntity to StateVacuumEntity.
  • Services supported by VacuumEntity and StateVacuumEntity differ, but the documentation was a bit ambiguous causing some integrations to implement services from the wrong base class. This is now prevented by PR 95833. All core integrations are already updated, but custom component integration authors need to update their integrations.
  • The battery_icon + battery_level state attributes have been deprecated. Integrations can instead report battery status by adding a sensor with device class battery to the same device as the vacuum entity, see architecture discussion 938 for details.
  • The map state attribute has been deprecated. Integrations can instead provide a map image by adding an image entity to the same device as the vacuum entity, see architecture discussion 939 for details.
For more details, refer to the vacuum documentation.
