New scaling utils and import changes
New utils for scaling brightness
Multiple integrations have implemented there own scaling algorithm to scale brightness. New utils are introduced now to simplify the implementation of brightness scaling in homeassistant.util.color:
Python
def brightness_to_value(low_high_range: tuple[float, float], brightness: int) -> float:
    """Given a brightness_scale convert a brightness to a single value.
    Do not include 0 if the light is off for value 0.
    Given a brightness low_high_range of (1,100) this function
    will return:
    255: 100.0
    127: ~49.8039
    10: ~3.9216
If you'd rather like to scale brightness to an integer range you can also use scale_ranged_value_to_int_range, described here.
Python
def value_to_brightness(low_high_range: tuple[float, float], value: float) -> int:
    """Given a brightness_scale convert a single value to a brightness.
    will return:
    100: 255
    50: 127
    4: 10
    The value will be clamped between 1..255 to ensure valid value.
This also ensures a valid brightness value is returned.
Background
To scale fan speed percentage we already have some utils homeassistant.utils.percentage:
Python
def ranged_value_to_percentage(
) -> int:
and
Python
def percentage_to_ranged_value(
    low_high_range: tuple[float, float], percentage: int
) -> float:
These percentage utils will now use new generic scaling utils in homeassistant.utils.scaling:
scale_ranged_value_to_int_range and scale_to_ranged_value
Python
def scale_ranged_value_to_int_range(
    source_low_high_range: tuple[float, float],
    target_low_high_range: tuple[float, float],
    value: float,
) -> int:
    """Given a range of low and high values convert a single value to another range.
    Given a source low value of 1 and a high value of 255 and
    a target range from 1 to 100 this function
    will return:
    (1,255), 255: 100
    (1,255), 127: 50
    (1,255), 10: 4
and
Python
def scale_to_ranged_value(
    value: int,
) -> float:
    Do not include 0 in a range if 0 means off,
    e.g. for brightness or fan speed.
    will return:
    (1,255), 255: 100
    (1,255), 127: ~49.8039
    (1,255), 10: ~3.9216
Utils int_states_in_range and states_in_range are moved
These utils are now under homeassistant.util.scaling. If these are used in your custom integration, make sure you update the import to the new module.
