Climate entity now supports independent horizontal swing
As of Home Assistant Core 2024.12, we have implemented an independent property and method for controlling horizontal swing in ClimateEntity.
Integrations that support completely independent control and state for vertical and horizontal swing can now use the previous swing_mode for vertical swing only and use the new swing_horizontal_mode for providing the horizontal swing state and control.
Integrations that don't have independent control should still keep using the current swing_mode for both vertical and horizontal support.
Example
Example requirements to implement swing and swing_horizontal in your climate entity.
Python
class MyClimateEntity(ClimateEntity):
    """Implementation of my climate entity."""
    @property
    def supported_features(self) -> ClimateEntityFeature:
        """Return the list of supported features."""
        return ClimateEntityFeature.SWING_MODE | ClimateEntityFeature.SWING_HORIZONTAL_MODE
    @property
    def swing_mode(self) -> str | None:
        """Return the swing setting.
        Requires ClimateEntityFeature.SWING_MODE.
        return self._attr_swing_mode
    @property
    def swing_modes(self) -> list[str] | None:
        """Return the list of available swing modes.
        return self._attr_swing_modes
    @property
    def swing_horizontal_mode(self) -> str | None:
        Requires ClimateEntityFeature.SWING_HORIZONTAL_MODE.
        return self._attr_swing_horizontal_mode
    @property
    def swing_horizontal_modes(self) -> list[str] | None:
        return self._attr_swing_horizontal_modes
    async def async_set_swing_mode(self, swing_mode: str) -> None:
        """Set new target swing operation."""
        await self.api.set_swing_mode(swing_mode)
    async def async_set_swing_horizontal_mode(self, swing_horizontal_mode: str) -> None:
        """Set new target horizontal swing operation."""
        await self.api.set_swing_horizontal_mode(swing_horizontal_mode)
More details can be found in the climate documentation.
