Changed config entry state transitions
Config entry state transitions when unloading and removing entries has been modified:
  • A new state ConfigEntryState.UNLOAD_IN_PROGRESS is added, which is set before calling the integration's async_unload_entry
    Rationale:
    • Make it easier to write cleanup code which should run after the last config entry has been unloaded
    • Improve debugging of issues related to reload and unload of config entries
  • The config entry state is set to ConfigEntryState.FAILED_UNLOAD when the integration's async_unload_entry returns False
    Rationale:
    • If async_unload_entry returns False, we can't assume the integration is still loaded, most likely it has partially unloaded itself, especially considering this is the pattern we recommend:
    Python
    async def async_unload_entry(hass: HomeAssistant, entry: MyConfigEntry) -> bool:
      """Unload a config entry."""
      # async_unload_platforms returns False if at least one platform did not unload
      if (unload_ok := await hass.config_entries.async_unload_platforms(entry, PLATFORMS)):
          entry.runtime_data.listener()
      # Finish cleanup not related to platforms
      return unload_ok
  • The config entry is removed from hass.config_entries before calling the integration's async_remove_entry is called
    Rationale:
    • Make it easier to write cleanup code which should run after the last config entry has been removed
Custom integration authors need to review and update their integrations' async_unload_entry and async_remove_entry if needed. The most common pattern which requires an update is this:
Python
async def async_unload_entry(hass: HomeAssistant, entry: ConfigEntry) -> bool:
    loaded_entries = [
        entry
        for entry in hass.config_entries.async_entries(DOMAIN)
        if entry.state is ConfigEntryState.LOADED
    if len(loaded_entries) == 1:
        # The last config entry is being unloaded, release shared resources, unregister services etc.
This can now be simplified, if the custom integration's minimum Home Assistant version is set to 2025.3.0:
Python
    if not hass.config_entries.async_loaded_entries(DOMAIN):
If the custom integration needs to be backwards compatible with previous releases of Home Assistant Core:
Python
    other_loaded_entries = [
        _entry
        for _entry in hass.config_entries.async_loaded_entries(DOMAIN)
        if _entry.entry_id != entry.entry_id
    if not other_loaded_entries:
Check the config entry documentation, and the home assistant core PR #138522 for additional background.
