The result attribute has been removed from the FlowResult typed dict
The result attribute has been removed from the homeassistant.data_entry_flow.FlowResult typed dict, and is now present only when needed, i.e. homeassistant.auth.models.AuthFlowResult and homeassistant.config_entries.ConfigFlowResult.
The change is not expected to affect runtime behavior of custom integrations, but custom integration authors may need to update tests and any classes derived from homeassistant.data_entry_flow.FlowResult that use a result attribute, to silence type-checker warnings.
