Improved error handling for oauth2 configuration without internet
Integrations using Application Credentials and Configuration via OAuth2 need to update their error handling to correctly handle configuration when the internet is down.
Currently integrations using configuration via OAuth2 call config_entry_oauth2_flow.async_get_config_entry_implementation in async_setup_entry in their __init__.py. Previously when there was no network, this would raise ValueError: Implementation not available, which was a non-retryable error, resulting in the integration needing to be manually reconfigured after internet was restored (see Issues 153956 and 144582). core PR 154579 added config_entry_oauth2_flow.ImplementationUnavailableError and raises it in config_entry_oauth2_flow.async_get_config_entry_implementation when OAuth2 configuration is unavailable because of missing internet. Integrations should catch this error and raise ConfigEntryNotReady. The changed behavior with the new exception will be released in 2025.12.
Here is an example of the migration,
Diff
-    implementation = await async_get_config_entry_implementation(hass, entry)
+    try:
+        implementation = await async_get_config_entry_implementation(hass, entry)
+    except ImplementationUnavailableError as err:
+        raise ConfigEntryNotReady(
+            "OAuth2 implementation temporarily unavailable, will retry"
+        ) from err
New integrations will find the correct try / except block generated by python3 -m script.scaffold config_flow_oauth2.
