Remove deprecated light features
Summary of changes
In October 2022, Home Assistant migrated the preferred color temperature unit from mired to kelvin.
In February 2024, Home Assistant requested explicit supported_color_modes and color_mode properties (triggering deprecation of legacy fallback color mode support).
In December 2024, Home Assistant requested explicit Kelvin support (triggering deprecation of mired support).
It is now time to clean up the legacy code and remove the corresponding attributes, constants and properties:
  • Remove deprecated ATTR_COLOR_TEMP, ATTR_MIN_MIREDS, ATTR_MAX_MIREDS, ATTR_KELVIN, COLOR_MODE_***, and SUPPORT_*** constants
  • Remove deprecated state attributes ATTR_COLOR_TEMP, ATTR_MIN_MIREDS and ATTR_MAX_MIREDS
  • Remove deprecated support for ATTR_KELVIN and ATTR_COLOR_TEMP arguments from the light.turn_on service call
  • Remove deprecated support for LightEntity.color_temp, LightEntity.min_mireds and LightEntity.max_mireds properties from the entity
  • Remove deprecated support for LightEntity._attr_color_temp, LightEntity._attr_min_mireds and LightEntity._attr_max_mireds shorthand attributes from the entity
Additionally, failing to provide valid supported_color_modes and color_mode properties no longer works and will raise an error.
Examples
Custom minimum/maximum color temperature
Python
class MyLight(LightEntity):
    """Representation of a light."""
    # Old
    # _attr_min_mireds = 200 # 5000K
    # _attr_max_mireds = 400 # 2500K
    # New
    _attr_min_color_temp_kelvin = 2500 # 400 mireds
    _attr_max_color_temp_kelvin = 5000 # 200 mireds
Default minimum/maximum color temperature
Python
from homeassistant.components.light import DEFAULT_MAX_KELVIN, DEFAULT_MIN_KELVIN
    # Old did not need to have _attr_min_mireds / _attr_max_mireds set
    # New needs to set the default explicitly
    _attr_min_color_temp_kelvin = DEFAULT_MIN_KELVIN
    _attr_max_color_temp_kelvin = DEFAULT_MAX_KELVIN
Dynamic minimum/maximum color temperature
Python
from homeassistant.util import color as color_util
    # Old
    # def min_mireds(self) -> int:
    #     """Return the coldest color_temp that this light supports."""
    #     return device.coldest_temperature
    # def max_mireds(self) -> int:
    #     """Return the warmest color_temp that this light supports."""
    #     return device.warmest_temperature
    # New
    def min_color_temp_kelvin(self) -> int:
        return color_util.color_temperature_mired_to_kelvin(device.warmest_temperature)
    def max_color_temp_kelvin(self) -> int:
        return color_util.color_temperature_mired_to_kelvin(device.coldest_temperature)
Checking color temperature in service call
Python
from homeassistant.components.light import ATTR_COLOR_TEMP_KELVIN
    def turn_on(self, **kwargs: Any) -> None:
        """Turn on the light."""
        # Old
        # if ATTR_COLOR_TEMP in kwargs:
        #     color_temp_mired = kwargs[ATTR_COLOR_TEMP]
        #     color_temp_kelvin = color_util.color_temperature_mired_to_kelvin(color_temp_mired)
        # Old
        # if ATTR_KELVIN in kwargs:
        #     color_temp_kelvin = kwargs[ATTR_KELVIN]
        #     color_temp_mired = color_util.color_temperature_kelvin_to_mired(color_temp_kelvin)
        # New
        if ATTR_COLOR_TEMP_KELVIN in kwargs:
            color_temp_kelvin = kwargs[ATTR_COLOR_TEMP_KELVIN]
Background information
