Format entity names in custom cards
Frontend
As of Home Assistant 2026.4, the hass object exposes a formatEntityName helper. It is the same function used by the built-in cards (tile card, entity rows, ...) to compute the display name of an entity from its registry context (entity, device, area, floor). Custom cards can use it to produce names that stay consistent with the rest of the dashboard.
Given a temperature sensor named Temperature on a device named Thermostat:
JavaScript
const stateObj = hass.states["sensor.living_room_thermostat_temperature"];
hass.formatEntityName(
  stateObj,
  [{ type: "device" }, { type: "entity" }],
  { separator: " · " }
); // "Thermostat · Temperature"
The frontend also ships an entity_name selector. If your card uses the built-in form editor, you can offer users the same name picker the built-in cards use — accepting either a free-form string or a composition of registry items.
Take a look at the updated data documentation for the full reference and more examples.
