BrowseMediaSource: domain is now required
The BrowseMediaSource class in the media_source integration has been tightened up. The domain parameter is now a required str instead of str | None, and the special "list every media source" root node has moved to its own class, RootBrowseMediaSource.
Previously, domain was optional only to represent one edge case: the top-level node returned when browsing media-source:// with no specific source selected. That made the type hint misleading for the 99% case — every actual media source has a domain — and added a None branch that consumers had to think about. Splitting the root into its own class removes that branch.
What changed
  • BrowseMediaSource.__init__ now requires domain: str.
  • A new RootBrowseMediaSource class represents the root browse node listing all available media sources. It hardcodes domain=None and identifier=None and uses media-source:// as its content ID.
  • media_source.async_browse_media() and MediaSourceItem.async_browse() now return BrowseMediaSource | RootBrowseMediaSource.
Impact on custom integrations
Most integrations don't need any changes. If you implement a media_source.py platform, you were already passing your own domain to BrowseMediaSource — that keeps working.
You only need to act if:
  • You pass domain=None to BrowseMediaSource. This is no longer allowed. Set your integration domain instead.
  • You call media_source.async_browse_media() and annotate the result. Update the type hint to BrowseMediaSource | RootBrowseMediaSource, or narrow with isinstance() before using domain-specific attributes:
    Python
    from homeassistant.components.media_source import (
        BrowseMediaSource,
        async_browse_media,
    result = await async_browse_media(hass, media_content_id)
    if isinstance(result, BrowseMediaSource):
        # result.domain is guaranteed to be a str here
See the updated media source platform documentation for the full reference.
