Standard event types for button event entities
Button event entities now have a set of standard event types, provided by the new ButtonEventType enum. Integrations that use EventDeviceClass.BUTTON should use these types instead of custom strings whenever the interaction maps to one of them.
See the architecture discussion for the full background.
Why
Previously, each integration picked its own strings for button interactions — single, click, hold, double_press, and so on. This inconsistency made it impossible to build generic button automations that work across integrations, and prevented the frontend from offering meaningful trigger suggestions.
The new ButtonEventType standard event types solve this by giving every button integration a shared vocabulary for the common interactions.
The event types
ButtonEventType defines six standard event types:
  • ButtonEventType.PRESS_START: the button was pressed down.
  • ButtonEventType.PRESS_END: the button was released after a brief press (the standard "click").
  • ButtonEventType.LONG_PRESS_START: the button was held past a duration threshold.
  • ButtonEventType.LONG_PRESS_END: the button was released after a long hold.
  • ButtonEventType.MULTI_PRESS_ONGOING: an intermediate press in a multi-press sequence was detected.
  • ButtonEventType.MULTI_PRESS_END: a multi-press sequence completed.
The MULTI_PRESS_ONGOING and MULTI_PRESS_END events include a multi_press_count attribute in their event data (the ATTR_MULTI_PRESS_COUNT constant) with the number of presses.
None of these are mandatory. Unlike the doorbell ring event, there is no required type here. Each integration maps only the interactions its hardware can actually produce, and lists just those in event_types.
What to do
Import ButtonEventType from homeassistant.components.event and include the types your device supports in the entity's event_types. Fire them as the interactions happen:
Python
from homeassistant.components.event import (
    ATTR_MULTI_PRESS_COUNT,
    ButtonEventType,
    EventDeviceClass,
    EventEntity,
class MyButtonEvent(EventEntity):
    _attr_device_class = EventDeviceClass.BUTTON
    _attr_event_types = [
        ButtonEventType.PRESS_END,
        ButtonEventType.LONG_PRESS_END,
        ButtonEventType.MULTI_PRESS_END,
    @callback
    def _async_handle_multi_press(self, count: int) -> None:
        """Handle a completed multi-press sequence."""
        self._trigger_event(
            {ATTR_MULTI_PRESS_COUNT: count},
        self.async_write_ha_state()
Single-event devices
If a device only emits a single event per interaction, with no separate press and release, map it to the matching _end type (PRESS_END for short presses, LONG_PRESS_END for holds, and so on). This keeps the "button was pressed" trigger consistent across devices without synthesizing events the hardware never sends.
No migration required
This change only adds the shared constants; nothing is deprecated and no integration is forced to migrate. Custom event types are still allowed alongside the standard ones. Adopt ButtonEventType when it fits your device.
For full details, see the event entity documentation.
