New entity lifecycle hooks
Summary
Two new entity lifecycle hooks have been added:
  • Entity.async_prepare_to_add_to_hass allows integrations to run code before an entity is added to Home Assistant. It's available from Home Assistant Core 2026.10.
  • Entity.async_entity_id_changed is called when an entity's entity_id is changed in the entity registry. From Home Assistant Core 2026.11, an entity is no longer removed and added again when its entity_id is changed; it's updated in place instead.
Custom integrations which implement async_prepare_to_add_to_hass, async_added_to_hass or async_will_remove_from_hass need to opt in to in-place entity_id changes by implementing async_entity_id_changed. Until they do, their entities are still removed and added again when the entity_id changes. This backwards compatibility will be removed in Home Assistant Core 2027.11.
The lifecycle hooks are documented in entity lifecycle hooks.
Running code before an entity is added
The new hook
Python
async def async_prepare_to_add_to_hass(self) -> None:
    """Run before the entity is added to hass."""
async_prepare_to_add_to_hass is awaited on every add attempt, before the entity platform processes the entity's registry entry for this add attempt, and before the entity's state is written to the state machine. The entity's hass and platform attributes are assigned when the hook runs, but the hook must not rely on entity_id or registry_entry: depending on how the entity is added, they may be unset, set by the integration, or left over from an earlier add.
Unlike async_added_to_hass, the hook also runs for adds which will be aborted, for example because the entity is disabled in the entity registry, or because its entity_id or unique_id collides with an entity which has already been added. That's what makes it useful for work which must happen regardless of whether the entity ends up being added, but it also means code in the hook must not assume that the add will complete.
Raising an exception from the hook aborts the add.
This is implemented in core PR #182156, the rationale is described in architecture proposal home-assistant/architecture#1480.
Cleaning up
Since the add may be aborted, async_will_remove_from_hass is not guaranteed to run for an entity whose async_prepare_to_add_to_hass has run. Clean up of anything set up in the hook should be registered with async_on_remove, which is called both when an add is aborted and when a successfully added entity is removed:
Python
    await super().async_prepare_to_add_to_hass()
    unsubscribe = self._device.subscribe(self._handle_update)
    self.async_on_remove(unsubscribe)
Migrating from add_to_platform_start
Integrations have so far accomplished running code before an entity is added by overriding Entity.add_to_platform_start. That method is an implementation detail of the entity platform helper and is not meant to be overridden. Integrations which override it should override async_prepare_to_add_to_hass instead. The new hook takes no arguments; use self.hass and self.platform in place of the hass and platform arguments, and self.parallel_updates in place of parallel_updates.
Before:
Python
@callback
def add_to_platform_start(
    self,
    hass: HomeAssistant,
    platform: EntityPlatform,
    parallel_updates: asyncio.Semaphore | None,
) -> None:
    """Start adding an entity to a platform."""
    super().add_to_platform_start(hass, platform, parallel_updates)
    _async_register_thing(hass, platform.platform_name, self.unique_id)
After:
Python
    _async_register_thing(self.hass, self.platform.platform_name, self.unique_id)
Changing the entity ID in place
Until now, an entity was removed and then added again under its new entity_id when its entity_id was changed in the entity registry. This ran the entity's whole remove and add lifecycle again, including async_will_remove_from_hass and async_added_to_hass, even though for most entities nothing but the entity_id itself had to change.
From Home Assistant Core 2026.11, the entity is instead updated in place. Home Assistant removes the state under the old entity_id, sets self.entity_id to the new entity_id, moves its own bookkeeping (entity registry and device registry tracking, entity sources, restore state and entity groups) to the new entity_id, and writes the state under the new entity_id. async_will_remove_from_hass and async_added_to_hass are not called.
This is implemented in core PR #183946, PR #184943 and PR #185462, the rationale is described in architecture proposal home-assistant/architecture#1393.
The new hook
Entities which have set up anything keyed on their own entity_id can implement a new callback to update it:
Python
@callback
def async_entity_id_changed(self, old_entity_id: str) -> None:
    """Run when the entity_id has been changed in the entity registry."""
async_entity_id_changed is called after Home Assistant has removed the state under the old entity_id, moved its own bookkeeping and run async_registry_entry_updated. self.entity_id is already the new entity_id, the previous entity_id is passed as old_entity_id. Use it to update anything the state or attributes are derived from, for example state change listeners or dispatcher signals keyed on self.entity_id.
Writing the state from the hook is optional: if the state has not been written under the new entity_id when the hook returns, Home Assistant writes it. Work which needs the entity's own state under its new entity_id, for example rendering templates which reference this, should first write the state with self.async_write_ha_state().
Work which must be awaited can be done in a task; since entity registry updates are not serialized with it, check after each await that the entity is still added and that self.entity_id has not changed again.
The hook must call super(), so base classes can update their own bookkeeping. If the hook writes the state, it must call super() before doing so.
Exceptions raised by the hook are caught and logged by Home Assistant, and the entity_id change still completes: the state is written under the new entity_id. This is unlike async_prepare_to_add_to_hass, where raising an exception aborts the add.
Example:
Python
async def async_added_to_hass(self) -> None:
    """Run when the entity has been added to hass."""
    await super().async_added_to_hass()
    self._subscribe_signal()
    self.async_on_remove(lambda: self._unsub_signal())
@callback
def _subscribe_signal(self) -> None:
    """Subscribe to the signal for the current entity_id."""
    self._unsub_signal = async_dispatcher_connect(
        self.hass, f"{DOMAIN}_{self.entity_id}", self._handle_signal
@callback
    super().async_entity_id_changed(old_entity_id)
Note that the callback registered with async_on_remove calls whatever the current unsubscribe function is. Passing the unsubscribe function itself, as in self.async_on_remove(self._unsub_signal), registers the initial subscription's unsubscribe function: after the entity_id has changed, removing the entity calls that stale function again, and the new subscription leaks.
Backwards compatibility
An entity whose add and remove hooks depend on its entity_id would break if it was silently changed in place. To give custom integrations time to migrate, an entity of a custom integration is still removed and added again when its entity_id changes if one of the custom integration's own classes in its class hierarchy implements async_prepare_to_add_to_hass, async_added_to_hass or async_will_remove_from_hass, unless that same class or a subclass of it also implements async_entity_id_changed. Base classes provided by Home Assistant Core, such as SensorEntity or CoordinatorEntity, don't count, and entities of core integrations are always changed in place.
Custom integration authors should check whether their entities set up anything keyed on their own entity_id, and then implement async_entity_id_changed. If nothing needs to be updated, implementing it as a method which only calls super() is enough to opt in:
Python
@callback
    """Opt in to in-place entity_id changes."""
This backwards compatibility will be removed in Home Assistant Core 2027.11. After that, all entities have their entity_id changed in place.
Which hook to use
As a rule of thumb:
  • Use async_added_to_hass for the usual setup work: restoring state, subscribing to updates, registering listeners, fetching initial data. It runs as the last step of an add attempt, after the entity has its entity_id and its entity registry entry. It's not called for adds which are aborted earlier, for example because the entity is disabled, but the add can still fail after it has started: if it raises, if the add is cancelled, or if writing the first state raises.
  • Use async_will_remove_from_hass to undo work done in async_added_to_hass when a successfully added entity is removed. It's not called when the add fails.
  • Use async_prepare_to_add_to_hass only when the work genuinely has to happen before the entity platform processes the entity's registry entry, or has to happen even if the entity is disabled.
  • Use async_on_remove for clean up which must run both when an add is aborted or fails and when the entity is removed. This is the safe choice for anything set up in async_prepare_to_add_to_hass or async_added_to_hass.
  • Use async_entity_id_changed to update anything keyed on the entity's own entity_id when it changes. If the work needs the state under the new entity_id, write it with self.async_write_ha_state() first.
  • Do not override add_to_platform_start, add_to_platform_finish or add_to_platform_abort.
