Targets can exclude entities
Targeting an area, floor, or label is handy, until you want all of it except one or two things. Until now, the only way out was listing every entity separately, which loses the point of targeting the area in the first place.
So a target can now have an exclude block. It uses the same keys as the target itself, and Home Assistant removes whatever it matches from the resolved target:
YAML
action: light.turn_on
  floor_id: ground_floor
  exclude:
    area_id: kitchen
    label_id: night_light
Exclusions are resolved like the target, so they stay up to date. A light added to the kitchen later is left out as well. An exclusion applies to the whole target, including entities listed in the target directly. An exclude block on its own is not a valid target, and it can't be nested or use all or none.
Nothing to do for most integrations
If Home Assistant resolves the target for you, your integration supports exclusions already:
  • Entity actions registered with async_register_platform_entity_service or async_register_entity_service, including entity_id: all
  • Triggers and conditions built on the entity helpers, like make_entity_target_state_trigger
  • Code that uses service.async_extract_entities, service.async_extract_entity_ids, or target.async_extract_referenced_entity_ids
  • Triggers that follow a target with target.async_track_target_selector_state_change_event or TargetEntityChangeTracker
If you resolve targets yourself
cv.TARGET_FIELDS, cv.ENTITY_SERVICE_FIELDS, and cv.TARGET_SERVICE_FIELDS now accept exclude, and so does every schema built from them, like cv.make_entity_service_schema. If your code reads entity_id, device_id, or area_id from the target and resolves them on its own, it now accepts an exclude block and silently ignores it. That is worse than an error: the action or trigger then acts on exactly the entities the user asked to leave out.
Resolve the target with the target helpers instead. They apply the exclude block for you:
Python
from homeassistant.helpers import target as target_helpers
selection = target_helpers.TargetSelection(call.data)
selected = target_helpers.async_extract_referenced_entity_ids(
    hass, selection
entity_ids = selected.referenced | selected.indirectly_referenced
If your integration can't support exclusions, build its schema from cv.TARGET_ID_FIELDS. It has the target keys without exclude, so an exclude block fails validation instead of being ignored.
New public API
  • TargetSelection.exclude: the exclude block as a TargetSelection, or None. TargetSelection.has_any_target doesn't look at it, so a target with only an exclude block targets nothing.
  • target.async_extract_excluded_entity_ids(hass, target_selection): the entity IDs the exclude block matches.
  • cv.TARGET_ID_KEYS: the keys that select what a target refers to. Use them instead of the keys of cv.ENTITY_SERVICE_FIELDS when you require at least one target, like probatio.AtLeastOne(*cv.TARGET_ID_KEYS). That way a target with only an exclude block doesn't pass.
  • cv.TARGET_ID_FIELDS: the target fields without exclude.
The details are in entity actions and triggers and conditions. The background is in core pull request #187290.
