Apps will lose four default Linux capabilities
Every app container today gets the full default capability set of Docker, no matter what its manifest declares. The Supervisor is moving to a smaller set: NET_RAW, MKNOD, AUDIT_WRITE, and SETFCAP will no longer be granted implicitly. Capabilities listed in privileged are never dropped.
If you develop or maintain an app, this is what we ask of you: check whether your app opens raw or packet sockets, or otherwise depends on one of these capabilities, and if so add it to privileged now. The change is already in Supervisor 2026.09.3 behind feature flags, so you can test your app today. Supervisor 2026.12 turns the new defaults on for new installations, and later on they apply to all installations.
Docker's default capability set dates back to a time when containers were meant to run arbitrary software and be as compatible as possible. Several of the defaults are never needed by a well-behaved service, and some carry real risk. NET_RAW is the most prominent one: it allows raw and packet sockets, which a compromised app could use to interfere with traffic on its network. Kubernetes' restricted profile has dropped these four for years, and containerd is adding a reduced capability profile that removes exactly the same four. Dropping them also makes privileged a more accurate description of an app's additional privileges.
| Capability | What it allows | Who needs it |
NET_RAW |
Raw and packet sockets (SOCK_RAW, AF_PACKET), binding to any address |
Packet capture, port scanners, DHCP servers, ARP tools, and raw Bluetooth HCI |
MKNOD |
Creating device nodes with mknod |
Nothing in an app: the Supervisor bind-mounts the device nodes an app declares |
AUDIT_WRITE |
Writing records to the kernel audit log | sshd and PAM built with libaudit |
SETFCAP |
Setting file capabilities on executables | Package installs that run setcap in their post-install step |
Most apps need none of these. If your app does nothing listed under "Who needs it", it is very likely that no change is necessary: of the roughly 90 apps in the core and community stores, a handful need NET_RAW and none needs the other three.
The Supervisor adds these capabilities to the container's CapDrop, unless the app lists them in privileged. This applies to all apps, including those with full_access: true: the Supervisor never runs an app in Docker's privileged mode, and full_access only widens device access.
Supervisor 2026.09.3 and newer has the change behind two feature flags, off by default: app_drop_net_raw drops NET_RAW, and app_reduced_capabilities drops the other three. Turn on both with the ha CLI (5.1.0 or newer):
ha supervisor options \
--feature-flag app_drop_net_raw=true \
--feature-flag app_reduced_capabilities=trueCapabilities are fixed when a container is created. Restart the apps you want to test, which recreates their containers, then exercise their network features and watch the app log for Operation not permitted errors from tools or libraries that open sockets. Such an error is a starting point, not proof: confirm which capability the operation needs before adding it to the manifest. Inside the container, grep CapBnd /proc/self/status shows the bounding set of your own process: with both flags on and nothing requested it is 00000000000405fb, down from the Docker default 00000000a80425fb. To go back, set the flags to false and restart the apps. ha supervisor info shows the current state of all flags.
If testing shows that your app opens raw or packet sockets, add NET_RAW to privileged:
privileged:
- NET_RAWThe same works for AUDIT_WRITE, MKNOD, and SETFCAP; the configuration reference lists all accepted values. Only request a capability for something that actually fails, not for something that merely logs a warning, such as a failed setcap during a package install.
The most common worry about dropping NET_RAW is ping, since ICMP echo classically needs a raw socket. It does not break, and you do not need to test it. Linux has had ICMP datagram sockets since kernel 3.0 (IPv6 since 3.11), which work without NET_RAW as long as the process's group is within the net.ipv4.ping_group_range sysctl. That sysctl is per network namespace and already allows all groups on every supported installation:
For apps with their own network namespace, the Docker daemon sets it to
0 2147483647when it creates the container (since Docker 20.10, independent of the capability set). -
For apps with
host_network: true, the host's value applies. systemd sets the same value by default through its50-default.confsysctl drop-in, which Home Assistant OS ships:Shell$ cat /proc/sys/net/ipv4/ping_group_range 0 2147483647
We verified that busybox ping on the Alpine base and iputils-ping on the Debian base both work for IPv4 and IPv6 with NET_RAW dropped. That covers the ping monitor of Uptime Kuma, the ping node of Node-RED, and anything else that shells out to ping. An app that brings its own ICMP implementation, in a library or in its own code, needs to be tested: some use datagram sockets, some require raw sockets.
Tools that use raw or packet sockets may break, including nmap (as root it assumes raw sockets and quits unless run with --unprivileged), tcpdump, mtr, arping, fping, traceroute in ICMP mode, and DHCP servers. One more trap: a file capability like cap_net_raw+ep on a binary cannot grant what is missing from the container's bounding set, and with the effective bit set the kernel refuses to execute the binary at all. Some upstream images do this to ping. Check your image with getcap -r / and remove such file capabilities, or request the capability.
We went through the core and community app stores before adding the flags. Apps that need NET_RAW either already declared it or are being updated to: OpenThread Border Router and Matter Server (Bluetooth commissioning through raw HCI sockets) in the core store, and AdGuard Home (its DHCP server uses packet sockets), Tailscale, Advanced SSH & Web Terminal, and Studio Code Server (network tools such as nmap) in the community store. VPN apps such as WireGuard and ZeroTier only need NET_ADMIN and the /dev/net/tun device and work with all four dropped.
The other three capabilities have no consumer among the apps today. No app script calls mknod, no app runs an sshd built with libaudit, and setcap only shows up in post-install steps of packages such as fping or mtr-tiny installed at run time. Both apt and apk log a warning in that case and complete the install. This can show up in apps with a user-configurable package list, such as Advanced SSH & Web Terminal, Studio Code Server, JupyterLab, and AppDaemon.
Testing with the flags shows what breaks. If your app ships an apparmor.txt, AppArmor can also report which of these capabilities the app exercises before anything breaks. Do this with both flags off, since a dropped capability fails before AppArmor sees it. Add audit rules to the profile:
audit capability net_raw,
audit capability mknod,
audit capability audit_write,
audit capability setfcap,The Supervisor loads the profile when an app is installed or updated, so bump the version and update the app, or reinstall it. Each capability check that passes is then logged to the host journal (ha host logs, or journalctl -k on the host):
audit: type=1400 audit(...): apparmor="AUDIT" operation="capable"
profile="my_app" pid=1234 comm="tcpdump" capability=13 capname="net_raw"Read the result with the process name in mind. Tools that try a raw socket first and fall back, like ping, show up as using NET_RAW even though they work without it. The reverse holds too: the kernel skips auditing for some checks and rate-limits messages, so a missing line does not prove a capability is unused.
- Supervisor 2026.09.3 added the two feature flags, off by default (home-assistant/supervisor#7230 and home-assistant/supervisor#7233).
NET_RAWhas its own flag because it has a security implication of its own and known fallout in apps. The same release madeAUDIT_WRITE,MKNOD, andSETFCAPaccepted values inprivileged. - Supervisor 2026.12 turns both flags on by default for new installations (home-assistant/supervisor#7402). Existing installations keep their current behavior unless the flags are set. Restoring a backup does not carry feature flags over, so an app restored onto a new installation runs with the new defaults.
- No later than Supervisor 2027.05, the reduced capability set becomes the default for all installations. We may bring this step forward; if so, it is announced in the Supervisor release notes. The flags remain available for a while after the switch, so that a regression in an app can be confirmed by turning the old behavior back on, and will be removed in a later release.
If you run into problems or have concerns with the change, let us know in the Home Assistant Discord or open an issue on the Supervisor repository.
