Deleting the vacuum segments changed repair issue
Vacuum integrations that support CLEAN_AREA call async_create_segments_issue() when the vacuum reports segments that differ from the segments saved with the area mapping. Until now, integrations had no way to delete that repair again. The issue was only deleted after the user saved a changed area mapping. When the vacuum reported the saved segments again, the repair stayed open, and saving the mapping without changes didn't clear it either.
StateVacuumEntity now has a new method, async_delete_segments_issue(), to delete the issue again.
Call async_delete_segments_issue() when the vacuum reports the same segments as last_seen_segments. Calling it when no issue exists does nothing, so you can call it on every update.
from homeassistant.components.vacuum import Segment, StateVacuumEntity
from homeassistant.core import callback
class MyVacuum(StateVacuumEntity):
"""Representation of a vacuum."""
@callback
def _async_handle_segments(self, segments: list[Segment]) -> None:
"""Create or delete the segments changed repair issue."""
if (last_seen := self.last_seen_segments) is None:
# No area mapping has been saved yet
return
if {s.id: s for s in last_seen} != {s.id: s for s in segments}:
self.async_create_segments_issue()
else:
self.async_delete_segments_issue()The method deletes the issue by its issue ID. This means it also deletes an issue that was created before the entity was reloaded. Like async_create_segments_issue(), it raises a RuntimeError when the entity has no entity registry entry.
You don't need to call the method after the user saves a changed area mapping. The vacuum entity still deletes the issue itself in that case.
If your integration calls async_create_segments_issue(), also call async_delete_segments_issue() when the reported segments match last_seen_segments again. The MQTT vacuum platform does this from core PR #194248.
For more information, see core PR #194247 and the vacuum entity documentation.
