Updates for Custom UI and Custom Panels
Frontend
With the release of Home Assistant 0.70, we've migrated the build pipeline for our frontend from being based on HTML imports to ES module imports (more on this later). One of the effects of this is that we're no longer using the window object to share classes, data and utilities with other pieces of code.
This might impact you if you dependend on some of this. Examples are Polymer (window.Polymer) or one of our utilitity functions that used to be available as window.hassUtil, window.HAWS or window.hassMixins.
To give developers time to migrate, we're adding a temporary legacy support layer that will expose some of our internals again on the window object. We've already added window.Polymer, window.Polymer.Element and window.Polymer.html. If you're using other specific things from the window object, please let us know.
Th legacy support layer will no longer be included in releases happening after July 2018.
