Frontend component updates 2026.4
Frontend
Note
We do not officially support or encourage custom card developers to use our built in components. This component APIs can always change and you should build your card as independent component.
ha-input
We keep migrating our Material Design based components to Web Awesome based. This time we migrated the input components, which leads to an API change but the look and feel stays the same for now.
  • ha-input is the successor of ha-textfield
    • ha-textfield API stays but the component is migrated to use ha-input internally and will be removed in 2026.5
    • Also replaces ha-outlined-text-field
  • ha-input-search replaces search-input and search-input-outlined
  • ha-input-multi replaces ha-multi-textfield
  • ha-input-copy replaces copy-textfield
This component also introduces new semantic theme variables for form backgrounds:
CSS
--ha-color-form-background: var(--ha-color-neutral-95);
--ha-color-form-background-hover: var(--ha-color-neutral-90);
--ha-color-form-background-disabled: var(--ha-color-neutral-80);
Date picker
We finally removed the Vue 2 dependency by replacing the date and date range picker with Cally.
