Frontend new way of dialogs
Frontend
The Problem
Each dialog managed by the dialog manager was only opened once and stayed in the DOM for the lifetime of the application. This causes:
  • More memory usage: Dialogs accumulate in the DOM even when not visible
  • More bugs because of missing state reset: Dialog state persists between opens, leading to stale data or unexpected behavior
The Solution: DialogMixin
We implemented a new way of handling dialogs using DialogMixin. With this approach:
  • Dialogs are created when opened and destroyed when closed: No need to manually reset the state of the dialog when it is closed
  • Closed events are automatically handled: The dialog mixin takes care of cleanup
  • Subscribe mixin can now be used in dialogs: Since dialogs are properly destroyed, subscriptions are cleaned up automatically
  • Use normal Lit lifecycle methods: Use connectedCallback to initialize when the dialog is opened instead of relying on the showDialog method
Example
Check out ha-dialog-date-picker for a reference implementation. DialogMixin adds dialog params to this.params if available.
