Frontend component updates in 2026.7
Frontend
Component updates
Component sizes use Web Awesome names
ha-button, ha-button-toggle-group, and ha-slider now use the short Web Awesome size names.
For ha-button, use:
HTML
<ha-button size="s">Save</ha-button>
Supported values are xs, s, m, l, and xl.
For ha-button-toggle-group, use s or m:
HTML
<ha-button-toggle-group size="s" .buttons=${buttons}></ha-button-toggle-group>
ha-slider uses s or m.
If your custom card or editor still uses small, medium, or large on these components, migrate them to short values like s, m, or l.
Virtualized lists
We added two list components for large data sets:
  • ha-list-virtualized
  • ha-list-selectable-virtualized
Use these when a picker or dialog can render enough rows to affect scrolling or initial render time. The virtualized list renders only the visible rows while keeping the roving-tabindex keyboard navigation from ha-list-base.
Rows expose accessibility metadata with aria-setsize and aria-posinset, so assistive technologies still get the full list position even though only part of the list is in the DOM.
For selectable lists, render ha-list-item-option rows.
Context and editor infrastructure
Dirty state tracking
Dialogs and editors now have shared dirty-state infrastructure:
  • DirtyStateProviderMixin
  • dirtyStateContext
  • isDirtyState
  • isEffectiveDirtyState
Use DirtyStateProviderMixin for new dialogs or editors that need to block scrim close, enable Save only after edits, or coordinate dirty state with child components.
TypeScript
class MyDialog extends DirtyStateProviderMixin<MyState>()(LitElement) {
  public openDialog() {
    this._initDirtyTracking({ type: "shallow" }, this._state);
  private _stateChanged(state: MyState) {
    this._updateDirtyState(state);
isDirtyState is the raw comparison and is usually right for enabling Save. isEffectiveDirtyState can ignore equivalent config output, for example when an editor normalizes an explicit default back to the same effective config.
Pages and editors can now publish related context for nearby pickers:
  • relatedContext
  • fireRelatedContext
  • fireEntityRelatedContext
When a card editor, badge editor, automation trace page, or similar surface knows the current entity, device, or area, it can provide that context. Entity pickers and add-element searches can then prioritize related entities, devices, and areas.
TypeScript
fireEntityRelatedContext(this, "light.kitchen");
Clear the context with undefined when the editor no longer has a related item.
Narrow viewport context
narrowViewportContext exposes whether the main Home Assistant viewport is in the narrow layout.
Components that only need narrow-layout state can consume this context instead of receiving narrow through several layers of properties.
TypeScript
@consume({ context: narrowViewportContext, subscribe: true })
private _narrow!: boolean;
Lovelace updates
Strategy regeneration control
Lovelace strategies can now avoid unnecessary regeneration.
Strategies may declare registryDependencies to use the default reference-change check for only the registries they depend on:
TypeScript
static registryDependencies = ["entities", "areas"] as const;
For custom logic, implement shouldRegenerate():
TypeScript
static shouldRegenerate(config, oldHomeAssistant, newHomeAssistant) {
  return oldHomeAssistant.entities !== newHomeAssistant.entities;
If neither is provided, strategies keep the previous default behavior and regenerate on changes to entities, devices, areas, or floors.
