New radio frequency entity platform for RF device integrations
Home Assistant now has a radio_frequency entity platform that decouples RF transceiver hardware from the devices it controls. Instead of each device integration talking directly to specific RF hardware, transmitter integrations (like esphome) expose RadioFrequencyTransmitterEntity instances, and device integrations send commands through them via helper functions.
This mirrors the infrared entity platform and was approved in architecture discussion #1365.
Architecture
The radio_frequency domain sits between two types of integrations:
  • Transmitter integrations (ESPHome, Broadlink, …) implement the RadioFrequencyTransmitterEntity base class to provide hardware-specific RF transmission.
  • Consumer integrations (garage door openers, RF remotes, wireless switches, …) use helper functions to send device-specific RF commands through available transmitters.
Users select which transmitter to use during the consumer integration's config flow, filtered by the frequency the device operates on.
Implementing a transmitter integration
Transmitter integrations provide the radio_frequency platform by subclassing RadioFrequencyTransmitterEntity, declaring their supported_frequency_ranges, and implementing async_send_command:
Python
from rf_protocols import RadioFrequencyCommand
from homeassistant.components.radio_frequency import RadioFrequencyTransmitterEntity
class MyRadioFrequencyTransmitterEntity(RadioFrequencyTransmitterEntity):
    """My RF transmitter."""
    @property
    def supported_frequency_ranges(self) -> list[tuple[int, int]]:
        """Return the list of (min_hz, max_hz) ranges this hardware can transmit on."""
        return [(300_000_000, 348_000_000), (433_050_000, 434_790_000)]
    async def async_send_command(self, command: RadioFrequencyCommand) -> None:
        """Send an RF command."""
        await self._device.transmit(
            frequency=command.frequency,
            modulation=command.modulation,
            timings=command.get_raw_timings(),
The base class tracks the timestamp of the last sent command as the entity state, so transmitter integrations only need to handle the actual transmission.
Building a consumer integration
Consumer integrations control RF devices by sending commands through a transmitter entity. They don't interact with RF hardware directly. The snippets below are adapted from the honeywell_string_lights integration, which uses the platform to drive a Honeywell String Lights set.
1. Declare the dependency in manifest.json:
JSON
  "dependencies": ["radio_frequency"]
2. Load the device's commands from the rf-protocols library:
Python
from rf_protocols import get_codes
COMMANDS = get_codes("honeywell/string_lights")
Each loaded command exposes the frequency and modulation the device uses, which the config flow needs to filter transmitters.
3. Let the user pick a transmitter in the config flow, using a sample command to filter by the frequency and modulation the device requires:
Python
from homeassistant.components.radio_frequency import async_get_transmitters
from homeassistant.exceptions import HomeAssistantError
sample_command: RadioFrequencyCommand = await self.hass.async_add_executor_job(
    COMMANDS.load_command, "turn_on"
try:
    transmitters = async_get_transmitters(
        self.hass, sample_command.frequency, sample_command.modulation
except HomeAssistantError:
    return self.async_abort(reason="no_transmitters")
if not transmitters:
    return self.async_abort(reason="no_compatible_transmitters")
Only ModulationType.OOK (on-off keying) is supported right now; later releases can add other modulation types.
4. Send RF commands using the helper function and the stored transmitter entity ID:
Python
from homeassistant.components.radio_frequency import async_send_command
async def async_turn_on(self, **kwargs: Any) -> None:
    """Turn on the light."""
    command = await self.hass.async_add_executor_job(
    await async_send_command(self.hass, self._transmitter, command)
    self._attr_is_on = True
    self.async_write_ha_state()
RF protocols and codes
RF protocol encoders and device code sets live outside Home Assistant in the rf-protocols library. Common protocols and well-known device codes should be contributed there. For niche or proprietary protocols, a separate third-party library can also be used.
For full details, see the radio frequency entity documentation.
