Registering custom dashboard strategies
Frontend
As of Home Assistant 2026.5, you can now register custom dashboard strategies, just as you can with custom cards, making them easier to discover and add using the new dashboard dialog under the Community dashboards section.
Previously, you had to send users to create a blank dashboard, edit in YAML mode, and paste in your custom strategy. Now you can register a friendly name, description, and documentation.
To register your strategy, call window.customStrategies.push() with an object containing the following keys:
  • type: The strategy type without the custom: prefix, for example "my-demo".
  • strategyType: Set to "dashboard" to register a dashboard strategy.
  • name: The friendly name of the strategy.
  • description (optional): A short description of the strategy.
  • documentationURL (optional): A URL to the documentation for the strategy. This is not shown in the strategy UI yet but may in the future.
Example:
JavaScript
window.customStrategies = window.customStrategies || [];
window.customStrategies.push({
  type: "my-demo",
  strategyType: "dashboard",
  name: "My demo dashboard",
  description: "A starter dashboard generated from JavaScript.",
  documentationURL: "https://example.com/my-demo-dashboard",
This metadata is separate from the custom element itself. Your strategy still needs to be registered with a tag like ll-strategy-dashboard-my-demo, and users still need the resource loaded before Home Assistant can discover it. You can use HACS for this as other resources can be added, like custom cards.
Take a look at the updated custom strategies documentation with example code and further details.
