Live dashboard demos on any web page
Screenshots show what a card looks like. A live demo shows how it works: people can turn on a light, move a slider, and watch the other cards follow. The Home Assistant demo now publishes a script that does this on any web page, like the README site of your custom card, your blog, or these docs. Everything runs against a mocked backend in the browser, so no Home Assistant server is needed.
<ha-embed-provider>holds the mocked backend, with its entities and devices.<ha-embed-card>renders one card, built-in or custom.<ha-embed-section>renders one section, or a section strategy.<ha-embed-view>renders one view with its badges, a view strategy, or one view of a dashboard.<ha-embed-dashboard>renders a whole dashboard with its tabs, or a dashboard strategy.
The script follows the frontend of the release, so https://demo.home-assistant.io/embed.js always has the cards of the current release.
Every element comes from one script. Add it to your page once, and it loads its other files from the demo site:
<script
type="module"
src="https://demo.home-assistant.io/embed.js"
></script>Put the entities in a provider and the card configuration in a card. Both take JSON or YAML in a script tag, and the card configuration is the same as in a dashboard:
<ha-embed-provider>
<script type="text/yaml">
- entity_id: light.kitchen
state: "on"
attributes:
friendly_name: Kitchen
supported_color_modes:
- brightness
color_mode: brightness
brightness: 180
</script>
<ha-embed-card>
type: tile
entity: light.kitchen
features:
- type: light-brightness
</script>
</ha-embed-card>
</ha-embed-provider>All cards in the same provider share their entities, so changing the light in one card changes it in the others. To show your own card, load its script after the script of the demo and use its custom: type. A custom strategy loads the same way.
The same provider drives bigger layouts too. With the provider from above, this shows a dashboard with two tabs:
<ha-embed-dashboard style="height: 480px">
- title: Home
path: home
cards:
- type: tile
- title: Kitchen
path: kitchen
cards:
- type: light
</script>
</ha-embed-dashboard>A dashboard keeps its own current view, so the address of your page stays the same, and two dashboards on one page don't follow each other. Links to its own views, subviews and their back button, and links to anchors on your page all work. There is no edit mode.
If you maintain several cards or strategies, you don't need a demo site for each. Give each project a demo config, with the entities in entities and what to show in cards, sections, views, or dashboard. The configs can all live in the host site, or each project can keep its own, like a demo.yml next to its code:
entities:
state: "on"
attributes:
cards:
- type: custom:my-card
entity: light.kitchenThe site then renders each config: the entities go into a provider, and each card, section, view, or dashboard into its element, as YAML in their script tags. Load the script of each card after the script of the demo, and every project gets a live demo from one site. See Show several projects on one site for more.
The embed is built from the same code as the demo, in demo/src/embed/ of the frontend repository.
embed.js sets the public path of the bundle from its own URL, so its chunks, translations, and icons all load from the demo site, not from your page. Browsers only start workers from the page's own origin, so workers from the demo site, like the one of the markdown card, start from a small blob that imports the real script. The demo serves its files with CORS.
<ha-embed-provider> creates the same mocked hass object as the demo and the gallery, and registers the stubs of demo/src/stubs/ on it: actions, history and statistics made up from the current states (a few energy sensors of the demo get statistics of their own), weather forecasts, to-do lists, calendar events, energy, and the area, device, and entity registries. Lights, climate, covers, and other domains have specialized mocks, so their actions change their state the way Home Assistant would. The provider passes hass to its elements through a Lit context.
A card, section, view, or dashboard uses the provider around it, looking through shadow roots, so it works inside your own components. Outside a provider, it uses the first one on the page, or the provider attribute picks one by ID. That means one provider at the top of a page can feed cards anywhere in the text below it.
Cards render through hui-card, sections through hui-section, views through hui-view, and dashboards through hui-root, the same elements and strategy code as the dashboard panel. Cards take the width they would have in a section, so a 12 column grid lays out like a dashboard. The cards keep their styles in their shadow roots and follow the light or dark mode of the browser, or the color-scheme attribute of the provider.
The provider has a hass.mockEntities API to change entities from your page, and fires states-changed when they change. The elements read their script tags when they are set up, so you can also wait to load the script until a demo scrolls into view.
These docs use the embed already. Many entity pages show cards for their entity type, most dashboard card pages show their card live, and the docs for live demos show sections, views, and a dashboard you can explore.
- Show a live demo of your card: every element and option, with live examples.
- Areas, devices, calendars, and energy: data for cards that need more than entities.
- Change and watch entities from your page: drive a demo from your own script.
- What the mocked backend can do: the limits to keep in mind.
- The gallery and the demo: where the embed lives in the frontend, and how to add a mock your card needs.
