More device registry deprecations, new helpers and validation
Summary
This is a follow-up to Devices are restricted to a single config entry and at most one subentry, and covers additional device registry deprecations, a few new helper methods, and some stricter validation that landed after that post.
Most custom integrations won't be affected by this set of changes. Read on if your integration sets via_device or default_manufacturer / default_model / default_name in DeviceInfo, looks devices up in the registry, reads the registry's devices, deleted_devices or child_devices containers, calls async_update_device directly, or attaches a device to an entity that has no config entry or unique id.
Unless noted otherwise, deprecated functionality logs a warning at runtime and remains supported until Home Assistant Core 2027.8. As before, deprecations which are only relevant to core and core integrations are enforced more strictly there: those callers raise immediately, while custom integrations keep getting a warning until the removal version.
via_device follow-ups
The previous post deprecated DeviceInfo["via_device"] and DeviceRegistry.async_get_or_create(via_device=...) in favor of via_device_id, because identifiers are only unique per config entry and no longer point at a single device. A few related changes build on that.
Looking up a via device id: async_get_device_id_by_identifier()
To set via_device_id you need the device id of the via device. The new helper homeassistant.helpers.device_registry.async_get_device_id_by_identifier() looks it up, scoped to the config entry that owns the via device:
Python
@callback
def async_get_device_id_by_identifier(
    hass: HomeAssistant, identifier: tuple[str, str], *, config_entry_id: str
) -> str:
Python
via_device_id=dr.async_get_device_id_by_identifier(
    hass, (DOMAIN, hub_serial_number), config_entry_id=entry.entry_id
The lookup is unambiguous because identifiers are unique within a config entry. It raises ValueError if no matching device exists, so only call it once the via device has been created. When your integration creates the via device itself, skip the lookup and read .id from the DeviceEntry that async_get_or_create returned for it.
This helper was added in core PR #177494, which also migrated a number of integrations from via_device to via_device_id as examples.
via_device removed from the DeviceInfo type, and ATTR_VIA_DEVICE deprecated
Two typing-level follow-ups from core PR #178465:
  • via_device has been removed from the DeviceInfo TypedDict. A DeviceInfo literal that still sets via_device is now a typing error; use via_device_id.
  • The constant homeassistant.const.ATTR_VIA_DEVICE is deprecated. Importing it logs a warning; use the string "via_device_id" instead. It is removed in Home Assistant Core 2027.8.
The same PR also escalates the enforcement of the deprecations announced in the previous post — DeviceRegistry.async_get_device(), passing via_device to async_get_or_create(), and the add_config_entry_id / add_config_subentry_id / remove_config_entry_id / remove_config_subentry_id parameters of async_update_device(). Core and core integrations now raise RuntimeError when calling these, while custom integrations continue to log a warning until Home Assistant Core 2027.8.
A device can't be its own via device
A device may no longer set itself as its own via device (core PR #178194):
  • Passing via_device_id equal to the device's own id to async_get_or_create() or async_update_device() raises HomeAssistantError.
  • Passing the deprecated via_device referencing the device itself is ignored and logged now, and will raise from Home Assistant Core 2027.8.
The device registry storage is bumped to version 3.3 (introduced in Home Assistant Core 2026.8), which clears any existing via_device_id self-references on load. Integrations which previously worked around this by clearing the self-reference themselves can drop that code.
async_update_device(): merge_connections and merge_identifiers deprecated
Passing merge_connections or merge_identifiers to DeviceRegistry.async_update_device() is deprecated in core PR #178888. These parameters only add to the device's existing connections or identifiers; compute the full desired set yourself and pass it as new_connections or new_identifiers instead.
Core and core integrations raise RuntimeError when passing the merge parameters; custom integrations log a warning until Home Assistant Core 2027.9 (note this removal is one release later than the others).
Finding a device's config entry for a domain: async_get_device_and_config_entry_for_domain()
A common pattern was to fetch a device and loop over its config_entries to find the config entry belonging to a given integration. Since DeviceEntry.config_entries is deprecated, core PR #178991 adds a helper that does this directly:
Python
@callback
def async_get_device_and_config_entry_for_domain(
    hass: HomeAssistant, device_id: str, *, domain: str
) -> tuple[DeviceEntry | None, ConfigEntry | None]:
Python
device, config_entry = dr.async_get_device_and_config_entry_for_domain(
    hass, device_id, domain=DOMAIN
It returns (None, None) for an unknown or child-device id, and (device, None) when a main device exists but no config entry of domain owns it. For a pre-migration composite id it returns a matching split device and its config entry, or the restored composite device and None when no split matches. The helper does not check whether the config entry is loaded, so keep your own ConfigEntryState.LOADED check if you need one.
The devices, deleted_devices and child_devices containers are protected
The DeviceRegistry.devices, DeviceRegistry.deleted_devices and DeviceRegistry.child_devices attributes used to be dictionaries keyed by device id, and integrations sometimes read them directly — registry.devices.get(device_id), registry.devices.values(), or device_id in registry.devices. The backing containers are now protected, and the public attributes are narrowed to what an integration legitimately needs.
devices (core PR #179578) is now a read-only collection of the registered devices. Iterating it yields the DeviceEntry values directly, and len() and value membership (device_entry in registry.devices) work as expected. Using it as a mapping — subscription, .get(), .values(), .keys(), or membership by device id (device_id in registry.devices) — is deprecated. The mapping surface keeps working as a backwards compatibility shim: core and core integrations raise RuntimeError, while custom integrations only log a warning. It is removed in Home Assistant Core 2027.9.
In practice, iterate with for device in registry.devices instead of registry.devices.values(), and look a device up by id with registry.async_get(device_id) instead of registry.devices.get(device_id).
child_devices (core PR #179713) is now a read-only collection of the child devices. It follows the container protocol — you can iterate it (it yields the child device entries), take its len(), and test value membership — and offers no dictionary-style access at all: there is no .get() or .values() and no lookup by device id. There is no backwards compatibility shim.
deleted_devices (core PR #179720) is an internal implementation detail of the device registry, and the whole attribute is now deprecated — there is no supported public use. Accessing it in any way is deprecated: core and core integrations raise RuntimeError, while custom integrations only log a warning. It is removed in Home Assistant Core 2027.9.
Testing what kind of device an id refers to
With direct container access going away, DeviceRegistry.async_get gains an include_composite_devices parameter to test what an id refers to (core PR #179594). With include_composite_devices=False, a pre-migration composite device id resolves to None:
Python
is_composite = (
    registry.async_get(device_id) is not None
    and registry.async_get(device_id, include_composite_devices=False) is None
This complements the existing include_child_devices and include_main_devices parameters, which similarly resolve — or exclude — child and main devices. DeviceRegistry.async_is_composite_device_id, introduced in the previous post, is now redundant and deprecated in the same PR; use async_get with include_composite_devices=False instead. It keeps working — core and core integrations raise RuntimeError, while custom integrations only log a warning — until Home Assistant Core 2027.9.
Attaching a device to an entity requires a config entry and a unique id
An entity may only attach a device if it has a unique id and belongs to a config entry. Attempting to attach a device from an entity without a config entry, or without a unique id, is now caught in entity_platform (core PR #177459): the device link is dropped and a warning is logged. This is only a warning for now, and will raise from Home Assistant Core 2027.8.
Note that the device link is already dropped today, even though the raise only lands in 2027.8 — an affected entity ends up with no device until it is given a unique id and a config entry.
Device info types are removed
The device registry used to classify each DeviceInfo as one of a fixed set of "device info types" (link, primary, secondary) based on which keys it contained. This existed to guess the primary integration for a device shared across several config entries, which is obsolete now that a device is owned by a single config entry. The classification is removed and replaced by lighter validation in core PR #179397, with the following developer-visible consequences:
  • DeviceInfo shapes that previously didn't match any type are now accepted. The old error "device info needs to either describe a device, link to existing device or provide extra information" is gone; a DeviceInfo still needs at least one of identifiers or connections.
  • Passing both a field and its default_ counterpart — for example both name and default_name, or model and default_model — now raises DeviceInfoError.
  • When a new device is created without a name, it now defaults to the config entry title for all device infos, not just those that were previously classified as primary. This can change the composed name of entities on devices that previously had no name.
default_manufacturer, default_model and default_name are deprecated
The default_manufacturer, default_model and default_name members of DeviceInfo are deprecated in core PR #179549. Pass the plain manufacturer, model and name fields instead.
These default_ fields let an integration that wasn't considered the primary one for a shared device suggest a name, manufacturer or model without overwriting the value set by the primary integration. A device now belongs to a single config entry, so there is no longer a primary integration to defer to, and the plain fields can be set directly.
The three fields have been removed from the DeviceInfo type, so setting them is a typing error, and passing any of them to async_get_or_create logs a warning. As with the other device registry deprecations, core and core integrations raise RuntimeError, while custom integrations keep working with a warning until Home Assistant Core 2027.9.
Entities which set these fields — device trackers, for example, set default_name — should pass the non-default variant instead:
Python
# Before
DeviceInfo(
    connections={(CONNECTION_NETWORK_MAC, mac)},
    default_name=f"Device {mac}",
# After
DeviceInfo(
Passing created_at or modified_at to async_get_or_create is deprecated
created_at and modified_at are managed by the device registry itself, and passing them to DeviceRegistry.async_get_or_create never had any effect — the values were ignored. Passing either is now deprecated in core PR #179998: core and core integrations raise RuntimeError, while custom integrations only log a warning, until Home Assistant Core 2027.9. Simply drop the arguments.
More examples
The changes above land alongside a large number of per-integration adaptations — migrating to via_device_id, using the new lookup helpers, and removing device self-references — which can serve as further examples. Search the core repository for pull requests referencing these APIs if you need a concrete migration to follow.
