DeviceEntry.config_entries deprecation is now enforced
Summary
The device registry's multi-config-entry compatibility properties — DeviceEntry.config_entries, DeviceEntry.config_entries_subentries and DeviceEntry.primary_config_entry — were announced as deprecated in Devices are restricted to a single config entry and at most one subentry, but reading them was still silent. They now report at runtime: core and core integrations raise RuntimeError, custom integrations log a warning.
Use DeviceEntry.config_entry_id and DeviceEntry.config_subentry_id instead. The properties remain available to custom integrations until Home Assistant Core 2027.10, two releases later than the 2027.8 given in the earlier post.
Reading the properties on a synthesized composite device is not deprecated and does not report, because such a device really does span several config entries.
Most integrations don't read these properties and don't need any changes. Read on if your integration inspects a device's config entries, or accesses them on a deleted or child device.
This is implemented in core PR #181949 and lands in Home Assistant Core 2026.10.
What reports, and what to use instead
Deprecated Replacement
DeviceEntry.config_entries DeviceEntry.config_entry_id
DeviceEntry.config_entries_subentries DeviceEntry.config_entry_id and DeviceEntry.config_subentry_id
DeviceEntry.primary_config_entry DeviceEntry.config_entry_id
As with the other device registry deprecations, the enforcement is stricter inside core: a core or core integration caller raises RuntimeError immediately, while a custom integration keeps working with a logged warning until Home Assistant Core 2027.10.
Migrating
A device belongs to exactly one config entry and at most one config subentry, so each of the shims collapses to a plain attribute read:
Python
# Before
entry_id = device.primary_config_entry
# After
entry_id = device.config_entry_id
Python
# Before
if config_entry.entry_id in device.config_entries:
# After
if device.config_entry_id == config_entry.entry_id:
Python
# Before
for entry_id, subentry_ids in device.config_entries_subentries.items():
    for subentry_id in subentry_ids:
# After
subentry_id = device.config_subentry_id
If you loop over a device's config entries to find the one belonging to your integration, use the async_get_device_and_config_entry_for_domain() helper introduced in More device registry deprecations, new helpers and validation instead:
Python
device, config_entry = dr.async_get_device_and_config_entry_for_domain(
    hass, device_id, domain=DOMAIN
Core's own test suite was migrated off the properties in core PR #181945, which can serve as a set of examples.
Composite devices are exempt
The properties are not deprecated for a synthesized composite device — the read-only device DeviceRegistry.async_get() returns for a pre-migration composite device id, as described in Backwards compatibility. Such a device spans several config entries, which config_entry_id and config_subentry_id can't represent, so the three properties are the correct API for it and reading them does not report, for any caller.
The exemption is keyed on DeviceEntry.is_composite_device, which code handling both kinds of device can branch on. Core's device_automation integration is a genuine example: the device ids passed to async_get_device_automations() come from automations, scripts and the frontend, so they can still be pre-migration composite ids, and listing a device's automations needs the domain of every config entry owning it:
Python
# homeassistant/components/device_automation/__init__.py
if (device := device_registry.async_get(device_id)) is None:
    raise DeviceNotFound
if device.is_composite_device:
    entry_ids = device.config_entries
else:
    entry_ids = {device.config_entry_id}
for entry_id in entry_ids:
    if config_entry := hass.config_entries.async_get_entry(entry_id):
        domain_devices.setdefault(config_entry.domain, set()).add(device_id)
Note that this is only needed for code which deliberately accepts a stored device id that may predate the migration. Code that only ever handles devices it registered itself should read config_entry_id unconditionally.
Deleted devices
DeletedDeviceEntry.config_entries and DeletedDeviceEntry.config_entries_subentries are deprecated and report on the same terms. A deleted device is never a composite, so there is no exemption — every read reports.
Use DeletedDeviceEntry.config_entry_id and DeletedDeviceEntry.config_subentry_id. Both are None for an orphaned deleted device, that is, one whose owning config entry has been removed; the deprecated properties represented that case as an empty set and an empty dict.
Child devices
ChildDeviceEntry inherits the three properties, and a child device is never a composite either, so reading them on a child device always reports. A child device belongs to the same config entry and subentry as its parent, both available as config_entry_id and config_subentry_id.
The WebSocket API and stored data are unaffected
This change only concerns the Python properties. A regular device is serialized as before — config/device_registry/list, the EVENT_DEVICE_REGISTRY_UPDATED payload and the device registry storage still carry the config_entries, config_entries_subentries and primary_config_entry fields, computed internally without reporting — so WebSocket clients are not affected and see no new warnings. Child devices never carried these fields in the first place.
Those fields are deprecated on their own schedule, described in Device registry WebSocket API changes.
