LLM tools return a ToolResult and declare their integration
As of Home Assistant Core 2026.10, an LLM tool returns an llm.ToolResult instead of a plain JSON object. ToolResult carries the tool's data and an error flag that says whether the call failed. On the chat log side, ToolResultContent.tool_result is replaced by ToolResultContent.result, which holds the ToolResult.
Returning a plain JSON object from a tool, reading ToolResultContent.tool_result, and setting tool_result on a tool result delta are deprecated. They keep working for custom integrations with a warning in the log until Home Assistant Core 2027.11, and stop working after that.
The release also adds metadata to llm.Tool. A tool now has a title for people to read, annotations that describe how it behaves, and an integration that records which integration provides it. The MCP Server integration serves the title and the annotations to MCP clients.
The annotations are an llm.ToolAnnotations with four flags: read_only, destructive, idempotent and open_world. The defaults describe the least safe case, so a tool that declares nothing is taken to write, to be destructive, and to reach outside Home Assistant.
Creating a tool without an integration is deprecated. A core integration raises an error. A custom integration gets a warning in the log until Home Assistant Core 2027.10, and stops working after that.
Both changes together look like this:
Python
from homeassistant.helpers import llm
from .const import DOMAIN
class GetItemsTool(llm.Tool):
    """Tool to read the items on a list."""
    name = "my_integration__get_items"
    title = "Get list items"
    description = "Read the items on a list."
    integration = DOMAIN
    annotations = llm.ToolAnnotations(
        read_only=True, destructive=False, idempotent=True, open_world=False
    async def async_call(
        self,
        hass: HomeAssistant,
        tool_input: llm.ToolInput,
        llm_context: llm.LLMContext,
    ) -> llm.ToolResult:
        """Call the tool."""
        return llm.ToolResult(data={"items": ["Milk", "Bread"]})
