Shared config flow abort reasons are translated centrally
As of Home Assistant Core 2026.10, the homeassistant integration can translate abort reasons that every integration words the same way. If you're today linking from a local translation key, for an abort reason, to a shared translation key under the homeassistant integration, you can instead just rely on the shared translation key under the homeassistant domain directly. This is done by default in some helpers and can also be done explicitly by setting the translation_domain parameter when aborting the flow.
What to do
  • Delete the keys below from the abort sections of strings.json, including those under config_subentries, only when the abort uses the homeassistant translation domain.
  • The helpers listed below use the central translation domain automatically.
  • If your code passes one of these reasons to async_abort or AbortFlow, pass the homeassistant translation domain before deleting the local key. Without that domain, retain the local key. See Explicit translation domain.
When an abort uses the central translation domain, the frontend resolves the reason from that domain and does not use a local key.
Default reasons
Reason Raised by
already_in_progress async_set_unique_id, discovery without a unique ID
single_instance_allowed single_config_entry, DiscoveryFlowHandler, WebhookFlowHandler
no_devices_found DiscoveryFlowHandler
cloud_not_connected WebhookFlowHandler
reauth_successful async_update_reload_and_abort, async_update_and_abort
reconfigure_successful async_update_reload_and_abort, async_update_and_abort, also for subentries
authorize_url_timeout AbstractOAuth2FlowHandler
missing_credentials AbstractOAuth2FlowHandler
no_url_available AbstractOAuth2FlowHandler
oauth_error AbstractOAuth2FlowHandler
oauth_failed AbstractOAuth2FlowHandler
oauth_implementation_unavailable AbstractOAuth2FlowHandler
oauth_timeout AbstractOAuth2FlowHandler
oauth_unauthorized AbstractOAuth2FlowHandler
user_rejected_authorize AbstractOAuth2FlowHandler
Pass the domain that owns the string. Both async_abort and AbortFlow accept it.
Python
from homeassistant.core import DOMAIN as HOMEASSISTANT_DOMAIN
return self.async_abort(
    reason="no_devices_found",
    translation_domain=HOMEASSISTANT_DOMAIN,
This works in config flows and subentry flows. Options flows look in the options section, which the homeassistant integration does not have.
Keep your own wording
Only needed if you word a reason differently on purpose:
  • Pass reason to async_update_reload_and_abort or async_update_and_abort, even with the default name.
  • In an OAuth2 flow, pass translation_domain=DOMAIN.
Aborts that core raises by itself, like already_in_progress, always use the central string, to keep a customized string there, overwrite the steps that produce the strings upstream.
