Always pass a step_id to flow results
When a step of a data entry flow shows a form, a menu, progress, or an external step, it now always has to pass a step_id. This goes for async_show_form, async_show_menu, async_show_progress, and async_external_step, in config flows, options flows, subentry flows, and repair flows alike.
Until now, step_id was optional. When you left it out, the flow manager filled in the step it had called. That goes wrong when one step method calls another directly: the result then gets the step ID of the first step, not of the step that built it.
Passing the step_id yourself removes that guesswork. The step_id is the name of the step method you are in, without async_step_:
async def async_step_user(
self, user_input: dict[str, Any] | None = None
) -> ConfigFlowResult:
"""Wait for the device to pair."""
if not self._pair_task:
self._pair_task = self.hass.async_create_task(self._async_pair())
if not self._pair_task.done():
return self.async_show_progress(
step_id="user",
progress_action="pairing",
progress_task=self._pair_task,
return self.async_show_progress_done(next_step_id="finish")- Core integrations and core code that leave out
step_idnow raise an error. All core integrations already pass it. - Custom integrations that leave it out log a deprecation warning. The flow manager still fills in the step it called, so your flows keep working until Home Assistant 2027.5.0.
In Home Assistant 2027.5.0, step_id becomes a required argument, and the fallback is removed. If you maintain a custom integration, search your flows for these four methods, and add the step_id where it is missing.
Read more in forms, menus, and progress.
