Plain device info dicts are deprecated in Bluetooth data updates
As of Home Assistant Core 2026.12, passing a plain dict as a device info in PassiveBluetoothDataUpdate(devices=...) is deprecated. It will stop working in Home Assistant Core 2027.12. Until then, Home Assistant converts the dict to a DeviceInfo and logs a warning.
This only concerns integrations that use a Bluetooth processor coordinator, either PassiveBluetoothProcessorCoordinator or ActiveBluetoothProcessorCoordinator. If yours doesn't, you can stop reading here.
Look at what your integration passes to devices:
What you pass to devices |
What to do |
The result of sensor_device_info_to_hass_device_info(), unmodified |
Nothing. It is already cached for you. |
A DeviceInfo you build once or cache |
Nothing. |
A new DeviceInfo for every advertisement |
Nothing is required, but caching it is worth doing. |
| A plain dict | Replace it before Home Assistant Core 2027.12. |
The result of sensor_device_info_to_hass_device_info(), with fields changed |
Fix this now. It has raised a TypeError since Home Assistant Core 2026.11. |
To check whether you are affected by the deprecation, search your logs for passes a plain dict as a device info in a PassiveBluetoothDataUpdate. The warning is logged the first time an update with a plain dict arrives, so your device needs to have sent an advertisement. You won't get it for every advertisement.
A DeviceInfo in place of the dict is all the deprecation asks for. We recommend also caching it, in a function that takes the values that can change:
from functools import lru_cache
from homeassistant.helpers.device_registry import DeviceInfo
# Old
def sensor_update_to_bluetooth_data_update(
parsed: ExampleUpdate,
) -> PassiveBluetoothDataUpdate:
return PassiveBluetoothDataUpdate(
devices={
None: {
"name": parsed.name,
"manufacturer": "Acme",
"model": parsed.model,
# The other fields of the update
# New
@lru_cache(maxsize=64)
def _device_info(name: str, model: str) -> DeviceInfo:
return DeviceInfo(name=name, manufacturer="Acme", model=model)
devices={None: _device_info(parsed.name, parsed.model)},
)The conversion quietly drops keys that are not device info fields, but DeviceInfo(...) raises a TypeError on them. If your dict has any, remove them when you migrate.
A device can send many advertisements per second, and each one goes through your code and through PassiveBluetoothDataUpdate.update(), which compares the device info with the one it has stored. If both are the same object, that check is over immediately. If they aren't, it compares every field, even though almost every advertisement carries the same values.
A plain dict is the slow way around this: it becomes a new DeviceInfo for every advertisement, so it never passes the quick check.
Here is what that looked like for a thermometer with four entities, measured while DeviceInfo became a dataclass. The machine was slow, so compare the ratios and not the absolute numbers:
| Device info, per unchanged advertisement | Time for the whole update |
Cached, using sensor_device_info_to_hass_device_info() |
About 6.7 µs |
A new DeviceInfo(...) |
About 9.3 µs |
A copy of the cached one, with sw_version set |
About 12.4 µs |
These are microseconds, so a single device won't make a difference you can notice. They do add up, because Home Assistant does this for every device in range. A cached DeviceInfo of your own passes the same quick check as the one from the helper.
When you cache a device info yourself, keep these in mind:
- The same object is shared by every advertisement with those values, so don't change it after your function returns it.
PassiveBluetoothProcessorEntitycopies the fields it needs, so the framework leaves it alone too. - Pass every value that can change as an argument, or a change won't reach the device registry. Arguments of an
lru_cachefunction must be hashable. Strings are, but sets aren't, so buildconnectionsandidentifiersinside the function. - Set
maxsizeabove the number of different devices you expect. With more devices than that, entries keep getting evicted, and you pay for rebuilding them.
sensor_device_info_to_hass_device_info() leaves values that are None unset. DeviceInfo(name=None) does not: it sets the name to None, and your entity loses its fallback to the coordinator name. If a value can be None, only set the field when it has a value.
sensor_device_info_to_hass_device_info() returns a shared, read-only device info, so setting a field on it raises a TypeError. The error message suggests copying it first. That works, but doing it for every advertisement is the slowest option in the table above. Build and cache your own instead, with the extra fields as arguments:
# Old: raises a TypeError
device_info = sensor_device_info_to_hass_device_info(parsed.device_info)
device_info.sw_version = parsed.sw_version
# New
def _device_info(
name: str | None,
manufacturer: str | None,
model: str | None,
sw_version: str,
) -> DeviceInfo:
# Leave the fields without a value unset, like the helper does
device_info = DeviceInfo(sw_version=sw_version)
if name is not None:
device_info.name = name
if manufacturer is not None:
device_info.manufacturer = manufacturer
if model is not None:
device_info.model = model
return device_info
device_info = _device_info(
parsed.device_info.name,
parsed.device_info.manufacturer,
parsed.device_info.model,
parsed.sw_version,
)A new firmware version gives you a different object with a different sw_version, so update() still sees the device change.
