Log unreachable devices at info level with UpdateFailedUnreachable
Home Assistant Core 2026.12 adds UpdateFailedUnreachable to the data update coordinator. Raise it from _async_update_data when the device or service cannot be reached. The coordinator logs the first failure at info level, instead of error, which is what the log-when-unavailable rule of the quality scale asks for.
The log-when-unavailable rule asks you to log once at info level when the device or service cannot be reached, and once when it can be reached again. With a coordinator, the second message was already there: Fetching <name> data recovered is logged at info level. The first one was not. Raising UpdateFailed logs Error fetching <name> data: <message> at error level, so an integration that moved to a coordinator started logging an error every time its device went offline.
UpdateFailedUnreachable is a subclass of UpdateFailed, so it behaves the same way: the entities of the coordinator become unavailable, the coordinator tries again at the next interval, and retry_after works too. Only the log message is different: the first failure is logged once at info level, as <name> is unavailable: <message>.
from homeassistant.helpers.update_coordinator import (
DataUpdateCoordinator,
UpdateFailedUnreachable,
class MyCoordinator(DataUpdateCoordinator[MyData]):
"""Fetch data for all entities."""
async def _async_update_data(self) -> MyData:
"""Fetch the latest data."""
try:
return await self.client.get_data()
except MyConnectionError as err:
raise UpdateFailedUnreachable(
translation_domain=DOMAIN,
translation_key="update_unreachable",
) from errSee the pull request for the full change, and Fetching data for more about the coordinator and its exceptions.
