Data Update Coordinator now supports Retry After
Integrations using the Data Update Coordinator can enhance the UpdateFailed exception with a new parameter retry_after to defer the next scheduled refresh by a specified number of seconds and then resume the normal cadence once the API has recovered.
In situations where polling API's would return a sign of being overwhelmed, by throwing an HTTP 429 or providing a Retry-After in the response header, integrations can now honor these backoff signals. The integration and API client must detect these backoff signals and sanitize the API's desired backoff period. The UpdateFailed exception accepts a retry_after parameter (a float in seconds) to delay the next scheduled refresh. Once the API recovers and UpdateFailed is no longer raised, the integration resumes its normal update_interval.
Example of the usage:
Python
try:
    request = await self.client.get_information()
except APIClientRateLimited as err:
    raise UpdateFailed(
        retry_after=60  # This can also be retrieved from the API response itself, or provide a default
    ) from err
ConfigEntryNotReady
The retry_after parameter is ignored during the Update Coordinator setup phase (async_config_entry_first_refresh). If the first refresh fails, Home Assistant raises a ConfigEntryNotReady exception, allowing config entry setup to retry automatically using the built-in retry. Once the coordinator setup succeeds, retry_after applies to following refreshes.
