Set up your DataUpdateCoordinator with a setup method
In Home Assistant 2024.8, we are introducing the _async_setup method for the data update coordinator. This method allows you to run asynchronous code to prepare your DataUpdateCoordinator instance or to load data that only needs to be loaded once.
You can override _async_setup in your coordinator, and it will be automatically called during coordinator.async_config_entry_first_refresh(). It offers the same error handling as _async_update_data and will handle ConfigEntryError and ConfigEntryAuthFailed accordingly.
Example
Python
class MyUpdateCoordinator(DataUpdateCoordinator[MyDataType]):
    prereq_data: SomeData
    def __init__(
        self,
        hass: HomeAssistant,
    ) -> None:
        """Initialize coordinator."""
        super().__init__(hass, _LOGGER, name=DOMAIN, update_interval=SCAN_INTERVAL)
        self.my_api = MyApi()
    async def _async_setup(self) -> None:
        """Do initialization logic."""
        self.prereq_data = await self.my_api.get_initial_data()
    async def _async_update_data(self) -> MyDataType:
        """Do the usual update"""
        return await self.my_api.update(self.prereq_data)
Avoiding checks for initialization status
This change allows you to refactor code that loaded the initial data in the _async_update_data method by checking an initialization variable, like
Python
async def _async_update_data(self) -> ...:
    if not self.something:
        self.something = self.client.fetch()
    return self.client.fetch_data()
into
Python
More information
Read more about this in the documentation
