Avoid unnecessary callbacks with DataUpdateCoordinator
The DataUpdateCoordinator can now reduce unnecessary updates when API data can be compared.
When using the DataUpdateCoordinator, the data being polled is often expected to stay mostly the same. For example, if you are polling a light that is only turned on once a week, that data may be the same nearly all the time. The default behavior is always calling back listeners when the data is updated, even if it does not change. If the data returned from the API can be compared for changes with the Python __eq__ method, set always_update=False when creating the DataUpdateCoordinator to avoid unnecessary callbacks and writes to the state machine.
