Frontend component updates in 2026.11
ha-md-list and ha-md-list-item were removed. Use ha-list-base with ha-list-item-base for static rows, or ha-list-item-button for clickable rows. The --md-list-item-* CSS properties no longer have any effect; use --ha-row-item-* and --ha-list-* instead.
ha-outlined-icon-button now builds on ha-icon-button instead of Material Web. Use --ha-icon-button-size for the size (default 40px) and the new --ha-outlined-icon-button-outline-color for the outline. The --md-outlined-icon-button-* and --md-sys-color-outline properties no longer have any effect.
The chips no longer use the Material Web property names. Rename the properties you set on ha-assist-chip, ha-input-chip and ha-filter-chip:
--md-assist-chip-* → --ha-assist-chip-*
--md-input-chip-* → --ha-input-chip-*
--md-filter-chip-* → --ha-filter-chip-*--md-sys-color-on-surface no longer colors the assist chip label; use --ha-assist-chip-label-text-color.
ha-formfield was removed, so a leftover ha-formfield no longer renders its label. ha-switch and ha-checkbox render their own label, so put the label in the control's default slot:
-<ha-formfield .label=${label}>
- <ha-switch .checked=${checked}></ha-switch>
-</ha-formfield>
+<ha-switch .checked=${checked}>${label}</ha-switch>The label is now a real <label> around the input, so clicking it toggles the control. When ha-switch is disabled, only the control is dimmed; the label uses --disabled-text-color.
The frontend stopped reading the --mdc-typography-* CSS properties. Setting them in a theme or on a component no longer has any effect; use the --ha-font-* theme variables, such as --ha-font-size-m and --ha-font-family-body, instead.
Themes can now set the background of every panel, not only of dashboards. The frontend paints the background once, behind all panels, so panels and layouts like hass-subpage and hass-tabs-subpage no longer paint their own. If your custom panel sets background-color: var(--primary-background-color) on its host, remove it, or it covers the theme background.
Three new theme variables control it. They take any CSS background value, so gradients and images work too:
--ha-panel-background: the background behind all panels. Defaults to--primary-background-color. Dashboards use it when the theme does not set--lovelace-background.--ha-panel-toolbar-background: the toolbars and sticky search bars, like the ones above data tables. Defaults to--primary-background-color.--ha-data-table-background: data tables. Defaults to--data-table-background-color.
