Frontend component updates in 2026.12
ha-list, ha-list-item, ha-check-list-item and ha-radio-list-item were removed. They were the last components built on Material Web Components, so the frontend no longer includes @material/mwc-list or any other mwc-* element.
Use the list family that also replaced ha-md-list in 2026.11. Pick the container by what the list means, and the row by what it does:
ha-list-basewithha-list-item-basefor rows that only show information, orha-list-item-buttonfor clickable rows. With anhref,ha-list-item-buttonrenders a link.ha-list-navfor a list of links. It wraps the list in a<nav>landmark.ha-list-selectablewithha-list-item-optionfor lists people pick from. Setmultito allow more than one option, andappearance="checkbox"on the options instead ofha-check-list-item. Withoutmulti, it replacesha-radio-list-item: the picked option is highlighted, there is no radio button.
The slots and attributes of a row map like this:
graphic="…" + slot="graphic" → slot="start"
hasMeta + slot="meta" → slot="end"
twoline + slot="secondary" → slot="supporting-text",
or the supporting-text attribute
default slot → slot="headline",
or the headline attribute
noninteractive → ha-list-item-base-<ha-list>
- <ha-list-item graphic="icon" twoline hasMeta @request-selected=${this._open}>
- <ha-svg-icon slot="graphic" .path=${mdiWifi}></ha-svg-icon>
- Network
- <span slot="secondary">Connected over Wi-Fi</span>
- <ha-icon-next slot="meta"></ha-icon-next>
- </ha-list-item>
-</ha-list>
+<ha-list-base aria-label="Settings">
+ <ha-list-item-button
+ headline="Network"
+ supporting-text="Connected over Wi-Fi"
+ @click=${this._open}
+ <ha-svg-icon slot="start" .path=${mdiWifi}></ha-svg-icon>
+ <ha-icon-next slot="end"></ha-icon-next>
+ </ha-list-item-button>
+</ha-list-base>The events changed too. A clickable row fires a regular click instead of request-selected. ha-list-selectable fires ha-list-item-selected and ha-list-item-deselected instead of action and selected:
- The index is now
detailitself, a number, instead ofdetail.index. - Without
multi,selectedhad the index of the picked row. Listen toha-list-item-selectedinstead. - With
multi,selectedhad the set of all selected indexes. The new events name one option at a time, so keep track of the selection yourself, or read theselectedproperty of the options.
The --mdc-list-* CSS properties no longer have any effect; use --ha-list-padding, --ha-list-gap and the --ha-row-item-* properties instead. The new lists have no padding of their own, so set --ha-list-padding: 8px 0 to keep the spacing of the old list.
See the new list family on the list page for all attributes, slots, and events.
